Measuring Total Plane Drag
ORIGINAL: da Rock
Have you an explanation for consideration of density altitude? I've been recording it since the 70s whenever I do any kind of testing, especially prop tests. Most would be amazed exactly how much it differs, even from day to day. And not many would realize how much it affects our model performance. It's probably the one most important unknown that makes a great deal of our testing of little real value.
As an aside, nowadays it's actually quite easy to take very accurate readings of it. There are handheld "weather stations" quite reasonably priced that do quite an excellent job of recording just about everything.
I can't speak for Rotaryphile but my Terminal Dive calculation assumed 90F and 500 ft for the air density number. Austins about 200 ft above sea level and HOT and I need about 300 feet to pull out. Naturally each data run would have an actual temperature and ground pressure recorded. I use a La Crosse weatherstation thats battery powered.
ORIGINAL: iron eagel
CC
I hope you are able to get access to a wind tunnel, I am very interested to see the results of the test.
CC
Do you by chance have access to an unmodified Duellist twin to compare the data with? I am intrigued to see how much of a difference that reduce frontal area, improve the nose and nacelle transition can make.
I would love to take something like the "Velocity" and create a dual tractor powered version.
Also as I have an real interest in the particular area that you are dealing with I am curious to the results such efforts make .
I would love to see more instrumentation for our models become available, to allow for us to obtain more data.
One thing I've noticed upon reading some of these calculations for speed, thrust, weight, and power is that they are neglecting the friction robbing effect of air resistance making their solutions questionable at speeds over 60mph and wildly invalid at speeds anywhere over 100! I've seen several posts mostly on other threads predict speeds based on power at over 200mph without ever considering air resistance. Converting weight/thrust ratios times velocity and other tricks are also invalid.
Ratio's, formulae, and such are often very convenient but designed to only work under a very narrow and specific set of conditions to make the calculations less cumbersome. It gets misused (abused) when someone applies this simplification in a much different context. Other people read this and validate it as reasonable and the error is taken up as a fundamental truth. I hope we can get back to some fundamental physics and quite using tricks.
From post #12:
"The way I found area for the wing was by finding the largest cross-sectional area of the wing panel perpendicular to the airflow. I found the thickest point of the root rib, added skin thickness and multiplied that number by the length of the panel. I then subtracted a triangular area to compensate for change in thickness from root to tip. "
I thought I made a mistake too so I checked it, THREE times! Heres the dimensions, go for it.
Root max th: 2.1875"
tip max th: 1.4375"
span: 69.0"
wing area: 125in^2
plane total: 155in^2
I have the plane framed up and simply looking at it head on confirms the numbers. It's all wing. The tail feathers are thin sheet, the fuse is a small bullet shape and the nacelles are buried in the wing and small also. It'll be equipped with retracts.
tip max th: 1.4375"
span: 69.0"
wing area: 125in^2
#32
ORIGINAL: HighPlains
How are you figuring frontal area? The 80% number is highly unlikely.
My calculations blew me away when I discovered the wing is over 80% of the total.
Well, I hate to break the news to you, but the air doesn't care one whit what the frontal area of the wing is. But fear not, it is the most common error in looking at drag. Didn't you read what Banktoturn wrote on the subject in this thread?
BankToTurns comment was a suggestion to use planform area (wing area). Using planform area the percentage of wing area to total area jumps to 96% because of the much larger area involved (and you seemed to have heartburn with 80%!). I was unsure about Banktoturns suggestion of using planform area instead of frontal area so I checked some other sources. It turns out that both frontal and planform are widely used in different instances.
When plotting airfoil polars the coefficient of lift Cl must be calculated using planform area so its convenient when comparing lift to drag on the same plot to use planform area for drag. This is an often cited example.
However, the purpose of my thread is to find parastic drag and the main form of consequence here is the profile drag based on the SHAPE of the entire machine. Since I must use frontal area for the fuselage and nacelles it is more consistent mathematically in this instance to use frontal area for the wing. The only difference will be the magnitude of the drag coefficient Cd of the plane. That, if you had actually understood Banks post, was the thrust of his point.
This is really more explanation than this muddled attack deserved but since it's a grey area I thought it might be interesting.
Any more observations HP? Got any new ratio's for us?
#36
I was designing the gear and discovered that the landing gear can make 60% of the total drag...looks innocent little gadget but can kill the whole economy of the plane when you don't have enuf power to leave the ground. So watch it.
#37
Towing a drag chute could get a bit complicated, since the drag of a parachute varies quite a bit with shape, but the parachute drag could be calibrated in a relatively small wind tunnel, or perhaps by towing behind a car on a towline long enough to get it out of most of the wind wash generated by the car.
Most university engineering departments have wind tunnels, but they usually have rather small test sections. Only a few of the larger universities commonly have wind tunnels with test sections larger than about two feet square, and they are very costly to operate. I did some engineering work to fix an underperforming wind tunnel recently which had a test section of about three feet square, and consumed about 300 HP to produce about 150 mph wind, generating quite an electric bill in the process.
