RE: clutch system installation???
turns out the brass fitting that the engine alrady had was the collet. so now let me get this straight. first the collet, then the flywheel, then the flywheel nut(how tight should i make this)then it looks like theres a washer then the bigger clutch bearingthen the clutch bell then the little bearing , then the clutch nut and screw? my hardware came w/ soe washers to, lttle white skinny ssmall washers and a few bigge rwaqshers. where in the line up do they go. sorry about no pic'. clay unruh oh yeah what about lube for the bearings wd40 or what?
