RCU Forums - View Single Post - Cellpro 10 balancing adapter warning
Old 04-13-2009 | 01:26 PM
KeithB's Avatar
KeithB
Default Cellpro 10 balancing adapter warning
This weekend I ruined a $550 battery due to a simple mistake when using the Cellpro 10 with a Thunder Power 10s Extreme. I felt compelled to share this experiance to help others avoid this easy to make, but costly mistake. This post is not a slam of the Cellpro because otherwise I've been extremely happy with the charger, however, I do feel strongly that the design of the balancing adapter should either have one plug for 5s/4s, or some other method to help avoid this. Certinally having the plugs right next to each other is a bad idea.
Note, in my case I was using the Thunder Power adapter, but looking at the other adapter sockets I believe this could happen with other brands of batteries as well.
The attached image details the problem.
ID:	1179598   Click image for larger version
