ORIGINAL: rcnitrohead
Whats the fun in treating your truck like an ON/OFF switch? They gave is digital proportional control, use it!
I'd understand if it was wheelying under almost every throttle imput but cmon, its a 3.3.... Stick a good big block in there and you'll learn a thing or two about throttle control..
Well said but doing what you can to keep the front down ultimately means a faster truck. In which case lowering the front (with the back jacked up) and a hump pack as far forward as you can put it is a good idea. Maybe even a monoblock if your a big blocker. Softer rear springs will help also.
