RE: what to use instead of CA
I think one has to size up the project. If pins or tape are not used for assembly where parts have to be held until cured, then ca us used. You can use anything on hinges as long as you keep the joint clear, a little vaseline takes care of that. In building a kit, ca is a quick glue if you want to make headway. If not, then pin (very securely of course), glue (with any glue, as stated above, the Elmer's wood glue is great), sit back, bbq, watch the ball game, come back tomorrow and continue. You have to remember that the purpose of ca is to make a FAST joint or joining, and is used for convenience. Other than that, use what ever you like as long as it is strong, and all the wood glues are. Have fun!
