RE: Combo Recommendation
The Super Tigre engines are indeed powerhouses. Some are tough to break in and some are not. Some of them are difficult to seal the o-ring under the carb due to the ring being hardened. Once you get them broke in and tuned they are beasts. If you order one I strongly suggest picking up a remote needle valve for it. The stock needle is trim your nails close to the prop on all of em.
