 Combo Recommendation >
Old 04-14-2009 | 07:46 PM
Default Combo Recommendation
Having searched through RCU, I'd like to get some opinions - if you're so inclined to share . . .
Having a very good experience building my H9 Alpha, I've determined that my second plane (for a variety of reasons) will be a H9 Ultrastick 40.
Are there a good engine people would like to recommend for the Ultrastick? I'd like to keep it 2-stroke for now, for cost efficiency.
Old 04-14-2009 | 07:56 PM
ChuckW's Avatar
Default RE: Combo Recommendation
I say an OS .46-AX would be outstanding and a .55-AX would be even better. Actually any quality high performance .46 class engine will do the job well.
Old 04-14-2009 | 08:02 PM
55 ax would get my vote a sweet running motor with alot of power.
Old 04-14-2009 | 08:12 PM
jrcaster's Avatar
Just yank the engine out of the Alpha and drop it into the Ultrastick. It will work just fine and save you money... for now.
Old 04-14-2009 | 10:24 PM
My Feedback: (13)
Yes just trade engine over to H(. Hoever if you would like to keep the Alpha intact....cause you always need at least one back-up... Try the OS 46ax or Super Tiger 45. Both great engines. The OS is much easier to get going. The break-in on the ST45 requires more work; but seemed to have ALOT more power in my opinion - and cheaper too.
Old 04-15-2009 | 07:32 AM
mclina's Avatar
Yeah, the ST-45 is a real powerhouse for only $70. I am flying a .55AX on my Four Star 40 and it is amazing. It has unlimited vertical at 1/2 throttle. I find the OS engines are easier to set up. You just break in per the manual and they are trouble-free. My two Super Tigres have also been great, but they required a little more fiddling after break-in to get them reliable.
If you are not in a hurry, you can keep your eyes out for a sale. Hobby People regularly has some pretty amazing deals on Magnum 2 and 4 strokes. I got my OS .55AX from Tower last December for $119 shipped, and I am not a super saver member.
Good luck
Old 04-15-2009 | 12:40 PM
I've only had 3 SuperTigre's but all broke it easily for me. I kind of enjoyed running mine in on a test stand first...something to do on a rainy day. I hear a properly broken in ringed engine gives good service. Never worn one out so I cannot say.
But I sure liked the one I had - http://www3.towerhobbies.com/cgi-bin...?&I=LXFV72&P=0
Regards,
Clay
Old 04-15-2009 | 02:42 PM
jib
As mentioned above, just swap in your old engine for now. We did that with a TT GP42 on our H( US40. Yeah, this is the 42 bushinged engine. It was a sweet plane with that engine. We flew it for a while like than and we are now upgrading it to an Aviastar .53.
Great second plane, no matter what engine you put on it.
Jack
Old 04-15-2009 | 04:12 PM
Phoenixangel's Avatar
The Super Tigre engines are indeed powerhouses. Some are tough to break in and some are not. Some of them are difficult to seal the o-ring under the carb due to the ring being hardened. Once you get them broke in and tuned they are beasts. If you order one I strongly suggest picking up a remote needle valve for it. The stock needle is trim your nails close to the prop on all of em.
