Thanks for your reply. I will get a 10k oil for the diff.
TGO
ORIGINAL: squeeguk
You need to fill it with oil, clean out all the grease and whack some 10k oil in there. You will need the assembly tool, which is a bit of rubber which blocks the screw holes and prevents the oil from dripping out.
