ORIGINAL: toothman
my problem is that the rod stopers come unscrewed. wat can i do about that? is there anyother types? if so id like to know.
Are you using metal clevis on your throttle, then using a stop nut on the end of it?? If you are using metal clevis you should replace this with a nylon clevis. The reason for this is the metal to metal contact between the clevis and the throttle arm can create RF interference for your radio when the plane starts vibrating. If you replace this with a nylon clevis, you will not need a stop nut on the pushrod.
Ken
