ORIGINAL: flaminheli
I thought that since the carb had a pump in it and a needle then it should not allow fuel to run thru it unless it is getting pulses from the crankcase.
you might be right on that one. was wondering why this was never a problem in the past on other planes..........
carb rebuild might be in order.although, when I test ran this engine in a stand it ran fine
