Fuel tank siphoning help
NJ
Have my fuel tank mounted higher than the carb. bottom of tank is probably 3" higher than the carb. Siphoning bad enough that the gas is dripping out the carb and floods the engine as soon as it is primed so I can't get it to fire unless I take the plug out and dry it off.
any ideas how to eliviate this?
can't mount the tank any lower than it is and the engine is mounted inverted.
the fuel line runs straight out of the tank down to the carb
TX
I thought that since the carb had a pump in it and a needle then it should not allow fuel to run thru it unless it is getting pulses from the crankcase.
My Feedback: (19)
ORIGINAL: sodbuster 1
NJ
ORIGINAL: flaminheli
carb rebuild might be in order.although, when I test ran this engine in a stand it ran fine
NJ
it is a Walbro carb.
Matter of fact you hit it right on. The one time I did get it to run (very briefly) was setting the needles around one turn out. Once it caught it wouldn't stay running at one speed. Was all over the place.
Will order up a carb kit tomorrow
