ORIGINAL: Ed_Moorman
Jeremy, I answered you by PM & e-mail.
First, I am writing and RC Report is now on line at
www.rcreport.net.
Check it out.
As I recall, that is a Stick from Cedar Hobbies that was designed for 3D or quasi-3D flying. The controls are very wide. 3D planes just can not be flown fast. The wide controls flutter in a heartbeat. I did give you some solutions for flutter in the PM.
Your best bet if you want to fly full power is to replace the ailerons with 1 1/2"-2" aileron stock and use 4-40 rods. Fixing the last 3" out by the tip also helps as flutter starts at the wing tip. I am attaching a couple of pictures of 2 of my Sticks showing the fixed part out at the wing tip.
May I also suggest propping that thing for torque, not speed. Go with a big diameter, low pitch prop.
