ORIGINAL: joco1
putting together a new plane and i hooked up and binded my ar7000 receiver last night both lights flashed like they were supposed to and then went solid when i hit the bind button and all servos worked fine i was working on it tonight and both receivers kept flashing so i put the bind plug back in and re bound it again both lights went solid like they were supposed to but a little while later they started flashing again i dont know what this means all servos work fine while its flashing just like last night i had it on charge all night any help on what im missing or doing wrong
"then went solid when i hit the bind button and all servos worked fine "
just a question about what you said here, are you pressing the bind button, after the system is bound to the RX? When you press the bind button it puts the radio in range test on my radio " I have the JRx9303".
sticks
