 ar 7000 receiver flashing >
Old 04-19-2009 | 10:06 PM
Default ar 7000 receiver flashing
putting together a new plane and i hooked up and binded my ar7000 receiver last night both lights flashed like they were supposed to and then went solid when i hit the bind button and all servos worked fine i was working on it tonight and both receivers kept flashing so i put the bind plug back in and re bound it again both lights went solid like they were supposed to but a little while later they started flashing again i dont know what this means all servos work fine while its flashing just like last night i had it on charge all night any help on what im missing or doing wrong
Old 04-19-2009 | 11:14 PM
MetallicaJunkie's Avatar
Default RE: ar 7000 receiver flashing
try binding back to back twice,,,,,also make sure you dont disconnect the satellite rx you will have to bind again
Old 04-20-2009 | 02:44 AM
Sandmann_AU's Avatar
If the LEDs in one or both of your AR7000 receivers (the main and satellite) start flashing it means that at some point the receiver supply voltage dropped below 3.x volts and the software's automatically kicked in with it's "quick reconnect" feature. If you're playing with it on the ground and you've noticed it, it probably just means that you've turned the plane off and on again without turning off the radio. If it's happening in the air you might want to take a look at your receiver battery, switch etc to see where it's dropping voltage.
Old 04-20-2009 | 09:08 AM
ORIGINAL: joco1
"then went solid when i hit the bind button and all servos worked fine "
just a question about what you said here, are you pressing the bind button, after the system is bound to the RX? When you press the bind button it puts the radio in range test on my radio " I have the JRx9303".
sticks
Old 04-20-2009 | 10:17 AM
ChuckW's Avatar
Make sure you bind it correctly. Withe the transmitter off, insert the bind plug and power up the receiver. Then hold down the bind button and turn the transmitter on. Continue holding the bind button until the LED's stop flashing and the receiver links up. Now turn everything off, remove the bind plug and power back up. Everything should work perfectly. I've never had a problem with unbinding.
Another potential cause for the flashing LED's is low receiver battery voltage.
Old 04-20-2009 | 11:28 AM
it bound correctly i should have said 'after i binded the second time all the servos worked' sorry for the confusion!
Old 04-20-2009 | 11:44 AM
BarracudaHockey's Avatar
If you turn the reciever off, and don't turn the transmitter off an on, when you turn the reicever back on it will see its tranmitter on the last two channels it used, connect instantly, and flash the lights tell you that the power went out. Its not smart enough to know if you turned it off, disconnected the battery, or if you had a problem in flight.
When you cycle the transmitter it picks two new channels and when the receiver links up the lights will come on solid.
