RE: DL-50 engine
The spring doen't have enough strength to have an appreciable difference in wear on the servo or battery drain. You can unhook the end on the throttle arm if you wish but it's not necessary to cut it and you deffinately don't want to remove it completely, you would need a new carb in about a year.
