RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 04-21-2009 | 12:15 PM
  #4633
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: DL-50 engine
ORIGINAL: Moki 1.8
Change off subject here, when I fill my fuel tank and then disconnect from the fill line the fuel keeps running out. I installed my fuel T on the fuel line, was I suppose to instal it on the vent line? Are should I get a one way fuel valve and instal that on the line?
You need to make sure the end you are filling is higher than he the tank or it will leak out. Just hold it up as high as you can when you disconnect it and plug it.
