RCU Forums - View Single Post - Futaba 7cap/chp
Old 04-21-2009 | 12:52 PM
redfox435cat's Avatar
redfox435cat
Default RE: Futaba 7cap/chp
yes it uses crystals and should have one in it with the channel number on it. The radio has multiple model memory. SO you get a bunch of receivers with the same channel on it. To change plane you go into the settings and set it to the model your flying. I get these for new models. [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMHB1&P=0]flight pack[/link] For 80% of my stuff up to 60 sized I use the 3004 standard ball bearing servos, for trainers even a 3001 standard non ball bearing servo will work just fine. I usually get the flight pack without the nicd and get my own 2100mah nimh packs but the nicds are just fine. with these flight packs you'll also have to get a crystal [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBFK8**&P=V]futaba crystal[/link] Do not get a thrid party crystal. if you go with say a hi tec flight pack then get a hi tec crystal
the pics I've gone through a couple screen, notice the name and model number change, that's your different set ups for different plane, I think I have 5 on here at the moment and 4-5 on my other radio.
ID:	1184660   Click image for larger version
ID:	1184661   Click image for larger version
ID:	1184662   Click image for larger version
ID:	1184663   Click image for larger version
