RCU Forums - View Single Post - Fox Composites Eurofighter build thread
Old 04-22-2009 | 04:35 AM
J.F
Default RE: Fox Composites Eurofighter build thread
been busy with other stuff, so only managed to get the bits in place for attaching the removeable nose, and added a bulkhead and tray up in the nosespace area, which will probably hold batteries, depending on how my CG turns out.
Any ideas tips/ideas on how to make an easy canopy frame? Have the rough cut canopy but need to make a frame for it...
Also, why do some companies change from the "standard"? Spektrum servo on left, futaba on right, just a couple of mm difference makes all the difference when a couple of mm is all you have to work with!
ID:	1185055   Click image for larger version
ID:	1185056   Click image for larger version
