RE: Data Flight logger
HI, that"s
good info, I guess they should have been called Data Interface.
Rcpete
PS, off the Topic a bit, I see a problem with the 1/2 sec. lock out on the RX and the 2 sec. fail safe on the ECU.
Take this scenario as in Dom's crashs, first flight on a new plane and you need a lot of up trim to fly. The RX locks out for 1/2sec reboots with down elevator( needs to be rebinded for neutral) and crashes. Turbine Ecu. did not shut down on the 2 sec. failsafe.
