RCU Forums - View Single Post - Data Flight logger
Old 04-22-2009 | 09:17 AM
KC36330
Default RE: Data Flight logger
if the RX goes into hold the ECU will log the failsafe the same as if it were a PCM receiver. if the ECU or the RX loose power in a crash all data is lost from the ECU (at least on a JetCat) and it records last off as 'Power Fail', all data in the ECU will then be that of the previous flight.
