RE: DL-50 engine
Wait until you start spitting muffs on a $150k airframe on a frequent basis, or wearing the muffler mounting holes on the engine cylinder oblong because the gasket fell out. You'll change your mind about using a gasket then and become a proponent of support brackets. Until then keep building that flight time. Eventually you'll reach the point that it happens to you. Luck only carries so far.
