RCU Forums - View Single Post - cheap batts at TH....wow
Old 04-22-2009 | 03:38 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: cheap batts at TH....wow
Yes, you are right. Higher voltage batteries actually won't last as long as the same sized lower voltage pack. If you want to increase the time you can use a battery then you need increase the millamp rating. Higher voltage batts are good because they increase the speed and strength of the servos.
Ken
