ORIGINAL: jimmyjames213
so will a 6v 1400 mah battery about the same as a 4.8v 800 mah? (is that what you ment)
just asking so i know how much flight time i have.
Roughly yes.
The less binding there is on the linkages, the longer the flight time from the battery as the servos need to do less work.
The greater the mechanical advantage, the longer the flight time as well.
