RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 04-23-2009 | 05:56 AM
  #4651
Junaid Ali
Default RE: DL-50 engine
Its better that you use a 2000 maH or higher battery for the ignition since the current draw can go as high as 800 ma at full throttle. At this draw the voltage on a smaller pack will fall quite a bit after a couple of flights.
