RCU Forums - View Single Post - Nose Wheel Pushrod Bends Instead of Wheel Turning
Old 06-17-2003 | 12:28 PM
glowplug
Default Nose Wheel Pushrod Bends Instead of Wheel Turning
You said it's not binding, so that's good. Is the pushrod in a sleve? If not, you could slide the pushrod through a sleve and that should help. You could also switch to a larger diameter pushrod.
Mike
