RCU Forums - View Single Post - Nose Wheel Pushrod Bends Instead of Wheel Turning
Old 06-17-2003 | 01:28 PM
CyberPilot
Default Nose Wheel Pushrod Bends Instead of Wheel Turning
I had a similar problem in my old trainer. I used some scrap balsa to block the path of the push rod where I saw it bending. Basically I made small U shaped blocks and CA'd them in place.
I also had to re-align the two mounts where the nose wheel shaft attached to the firewall (it was tight).
Hope this helps,
CyberPilot
