RCU Forums - View Single Post - expensive plane needs battteries
Old 04-24-2009 | 01:21 PM
JAM MaxAmps's Avatar
JAM MaxAmps
Default RE: expensive plane needs battteries
Any two cell Li-Po will work with what your doing I can't tell you a runtime as I have nothing that runs those servo's let alone anything that uses that many. As far as a voltage regulator goes you'll have to search around for one, we don't sell any. Yes I would say you'll want to stay in that 3000 mAh range as well for the pack. We have rec. packs here: http://www.maxamps.com/products.php?cat=18 If you have the room you could also use a 3250 2S pack as well with a servo plug on it. For transmitter packs look here: http://www.maxamps.com/products.php?cat=66
Jason
