RE: Ugly Stick Build
Hey Nergal,
What are you using for hinges for your ailerons? I have had this Lazerworks short kit Stik for 3 years and now just getting it together. Fuse is assembled and the wing is together except for the top trailing edge because I want to put pieces of solid trailing edge inside the trailing edge sheeting so the hinges (probably Robart) will have some meat to hold them. I plan on bolting the wing on as you did.
