RE: AMP Micro Renegade Rigger...
NICE BOAT!!, Grant & I both run the X632 B/S and detongued. They really do scoot along with that prop, but you must watch the temp of the ESC & especially the motor. They can heat up really quick. Make sure you get the Turn fin curve lined up parallel with the bottom of the hull (to stop lift if angled up or sucking if angled too low) & make sure all the running gear is square & as described in the manual. I had to put a very slight toe in on my turn fin to get the boat to track straight, but testing will show if you need this or not.
You will love this little rigger. Good luck.
