I am rebuilding a Hangar 9 Arrow into a low wing plane. The reconstruction means that the servo tray is moving up into the fuse a bunch and the servos will now be installed inverted. I'll be using the same transmitter (JR Sport S400) and would love to avoid the hassle of removing my battery and switching the servos in the radio. Is it possible to switch the wires in the servo connector so that the servo will rotate opposite to what it does now? I've seen some threads here and there with mention of openning up the servo and de-soldering and re-soldering internally but this seems a bit extreme. I'd also like to avoid frying a receveir as I've seen hints of this happeneing also....
Thanks a bunch
Ryan
http://www.rcuniverse.com/forum/m_7164146/tm.htm
