RCU Forums - View Single Post - Servo reversing
Old 04-26-2009 | 05:42 PM
Dorsal's Avatar
Dorsal
My Feedback: (17)
Default RE: Servo reversing
In order to reverse a servo internally, you need to switch the wires on the motor inside the servo AND switch the wires on the potentiometer inside the servo. If you just switch the wires on the connector that plugs into the receiver, you will burn up the circuit board inside the servo, because it is NOT polarity protected. You might even fry the receiver.
