ORIGINAL: w8ye
I think Enya still sells some lefties
The Enya four stroke is reversible by swapping the cams
The Enya SS series two strokes are reversible by turning the front bearing housing 90 degrees to the right when standing behind the engine
Any of the old two strokes with a separate front bearing housings are reversible by rotating the front housing 90 degrees
Some Saitos are reversible by buying a certain cam intended for the rear cylinder of the inline twins
I had read this before but thank you for the confirmation. I also think you can have some fun with Enyas by playing with advanceing and retarding the cams. Increase/decrease valve overlap. Now, I just have to figure out how to save your post to my hard drive.
Regards,
Bill
