RE: Interference ???
Any vibration can cause interference . Check the prop balance and check the muffler for tightness . Dont use a gasket on the muffler use high temp sealer and be sure to use locktite on the bolts . If no balance or looseness issues are found replace the servo extension lead with a heavier gauge extension . If still no success replace the servo itself . Sometimes the pots get sensitive and will cause the servo to chatter .
