RE: How to program Dreamworks afterburner light
Arnaud,
Here is the procedure:
- Position throttle: full throttle
- Press programming-switch (hold 1 sec) After an initialization sequence, LED 1+3+4+5 are lit.
- Now bring your gas stick in the position where AB function should be OFF.
- Press programming-switch. LEDs will flash, then will be lit permanently
- Now bring your Throttle stick to the position where you desire the AB ON
- Press programming-switch. After an initialization sequence, LEDs will be lit permanently
- AB Module returns to normal operation mode. You are finished.
If Anything went wrong with the programming, Remove power supply, wait 10 seconds, switch power supply on and restart the procedure.
