ORIGINAL: boxsterguy
That doesn't sound like a lot of time, but I'm sure I won't be at full throttle all that much. I'm still looking for an 8 oz. tank that will fit. It's a set screw on the front steering gear that is stopping the tank from going all the way down. I'v read where you can heat gun the tank into a new shape. I might try that.
Thanks again
Bguy
Can you flip the steering arm over so that it doesn't ride against the tank? I've had several of the Falcons and all with 8 oz tanks. I used K&B 40's on all of mine.
