RE: Help, ASP FS 61 AR muffler problem
...I got the new manifold and ran the engine at the weekend for the first time.
Holy cow! Is it normal that ASP 61 FS engines are vibrating that much? I rechecked in Youtube and is seems to be normal.
The cylinder head is vibrating to the left and right a quarter inch, alomst. Ok, the engine mount I use is rather soft but helps to protect the plane. After 30min break in I noticed some reduction but still...
Otherwise, the engine started easily by hand and I had no problems to adjust the needles (running on Coolpower 5%, O.S. F and 12x6 APC). The engine has lots of power too. And the sound! I realy like the sound of the engine. My little O.S. 30 FS does not come close to the ASP 61 FS.
But how could I get rid of the vibration? Should I use a glas filled engine mount? Now, the engine is screwed on wooden bearers.
