RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 04-27-2009 | 06:47 PM
  #4703
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: DL-50 engine
Here's 1 of the metering diaphragm 8-32 barb. The other three are the velocity stack I just installed.
You just tap the vent hole on an angle for 8-32. Have somebody silver solder the thing in after you snug it up....not too tight. Or use red lock tite like I did. Then grind the inside almost flush so it doesn't restrict the metering diaphragm movement. Very easy to do.
ID:	1188107   Click image for larger version
ID:	1188108   Click image for larger version
ID:	1188109   Click image for larger version
