ORIGINAL: jetpilot
MOST IMPORTANT!! After only 4 flight the wing retaining aluminum sleeves were nearly pulled out of wings. Couple more flights and the wing might have slipped off!!! Wing gap kept growing after each flight.
Wing tubes and stab dowels can slide into wings unevenly.
Been mentioned here alot but there are many hard points missing in flying surfaces.
Cockpits look great but are made out of some low grade plastic and wont last. Before the first flight they were pretty beat up.
canopy glass very low grade soft plastic
fin missing most of glue inside and main former was detatched. We changed to pull pull with solid carbon plate through rudder.
cockpit started deforming in sun
Landing gear mounts are insufficiant. One wing had a broken fromer glued in place. No support at all. We added carbon support braces.
Some of the pro version work was a little sloppy and our white version had white spray paint covering the proversion work done. Fit was good, but whats up with the white pray paint?
Nose gear door cylindrer was just glued to fuse wall with no support. Popped of before was even flown.
Winglet holes too big on one side so when tightened they gapped really big.
Tanks create alot of back pressure when installed per plans.
Intakes glued very sloppy and look nasty. They are very rigid though and feel very solid.
Scott
Hi, Scott
Thank you very much for the review with suggested, I will meeting with my staffs as soon, and we will check out all your points..and I will promise to you for Improve these points ....Thank you again.
Best regards
Anton
