RE: Need Help Reassembling
Make sure that the ring gap is lined up with the pin in the ring groove. Then conpress the ring, and slide the sleeve over. It should be a tight fit, but if there is any binding or if its going really tough, stop and make sure everything is in its proper place and not damaged.
also, make sure to oil the inside of the sleeve to prevent scoring when its sliding over the ring.
