Need Help Reassembling
Old 04-28-2009 | 03:24 PM
MetallicaJunkie's Avatar
Default Need Help Reassembling
I took a never run engine i bought from some one, and took it apart to make sure there was nor foreign crap in it....and now i cant get the sleeve over the piston the ring is in the way..... its a 160 fx
Old 04-28-2009 | 03:55 PM
andrew66's Avatar
Default RE: Need Help Reassembling
Make sure that the ring gap is lined up with the pin in the ring groove. Then conpress the ring, and slide the sleeve over. It should be a tight fit, but if there is any binding or if its going really tough, stop and make sure everything is in its proper place and not damaged.
also, make sure to oil the inside of the sleeve to prevent scoring when its sliding over the ring.
Old 04-28-2009 | 04:03 PM
The sleeve is chamferred at the bottom and if you apply gentle downward pressure while rotating the sleeve back and forth and making sure the ring is at the right place while the piston doesn`t tip, it should slide down.
PS. make sure to oil everything before you do it
Old 04-28-2009 | 04:07 PM
w8ye's Avatar
My Feedback: (16)
Don't you dare let the ring gap come across a port or you will be sorry
Everything will be locked up forever and in that case you will have to throw the engine away
Old 04-28-2009 | 05:11 PM
thanks for the advice, ill try to put it all together when i get home..... ive disassembled many engines and never have come across this problem..... yes the sleeve is chamfered, becuase of that i thought it was going to be a breeze getting it on.....
Old 04-28-2009 | 05:51 PM
kenhiraihnl's Avatar
while you're doing that, note that the arrow stamped on the top of the piston points to the exhaust port...ken
Old 04-28-2009 | 08:54 PM
finally i can relax now , and continue breaking her in....It runs sweet
[sm=thumbs_up.gif]
Thankyou
Old 04-28-2009 | 11:46 PM
w8ye's Avatar
My Feedback: (16)
Good, we are proud of you
