RE: Need Help Reassembling
The sleeve is chamferred at the bottom and if you apply gentle downward pressure while rotating the sleeve back and forth and making sure the ring is at the right place while the piston doesn`t tip, it should slide down.
PS. make sure to oil everything before you do it
