RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 04-28-2009 | 04:50 PM
  #734
cmoulder
Default RE: Phoenix Extra 330S 60-90 Size
I always breathe a huge sigh of relief when I finally confrim that the fin and stab are straight.
Getting the elevators operating identically is no problem with the Smart-Fly Equalizer. With Futaba, slaving Ch8 (or Ch7, whichever is last on the Rx) off Ch2 works quite well, although it does exhibit a very tiny lag in the slaved channel. Still, separate end points, centering, direction are very handy and works well for all but the most critical applications.
One servo with a split pushrod works well if you lay the servo on its side with the servo arm in the same plane of rotation as the elevator. Otherwise, the side-to-side motion will create unequal movement.
