RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 04-29-2009 | 07:19 PM
  #747
RICKSTUBBZ's Avatar
RICKSTUBBZ
Default RE: Phoenix Extra 330S 60-90 Size
Hey Bob,
The post that is two above this one sure looks to have a Decathlon in those pictures. Another one of my favorite birds.
Min2,
I do believe the right thrust debate will never end. For those that use it no one will talk them out of it. For those that do not use it no one can talk them into it.
Once upon a time I did not beleive in it. Even when I built a plane that was designed with it I would remove it. I had/have a little biplane that taught me the difference because I was bold enough to experiment and saw the difference first hand.
An alternate way to measure right thrust is to use a prop. This assumes the fuse wing and tail are square. Mark which ever tip you prefer so that you can use that tip for measuring each side. Measure from the prop tip to the elevator hinge line.
