RE: White Bondo????
YOU CAN USE MEK HARDENER. THE STUFF THATS USED WHEN YOU FIBERGLASS,, POLYESTER HARDENER..MIX IT IN GOOD.. HARD TO SEE IF ITS MIXIED.. LESS GIVES YOU MORE TIME .A BOUT 3 DROPS TO A GOLF BALL SIZE GLOB OF BONDO.. DO A FEW TEST GLOBS FIRST.. 1 DROP WILL STILL GET HARD.. OLD FIBERGLASS TRICK..FOR FILLETS.. LETS THE FILLET AND GLASS SET UP AT THE SAME RATE.. NO SHRINKAGE..
