White Bondo????
My Feedback: (57)
Billy,
I think most of the Bondo is white or whitish, it's the hardner (usually blue or red?) that tints it. There is a "white" hardener (BONDO# 20058) that should do the trick for you. I have never used the white hardener, so I can't comment on its use.
Hope this helps.
George
Hope this helps.
George
My Feedback: (41)
YOU CAN USE MEK HARDENER. THE STUFF THATS USED WHEN YOU FIBERGLASS,, POLYESTER HARDENER..MIX IT IN GOOD.. HARD TO SEE IF ITS MIXIED.. LESS GIVES YOU MORE TIME .A BOUT 3 DROPS TO A GOLF BALL SIZE GLOB OF BONDO.. DO A FEW TEST GLOBS FIRST.. 1 DROP WILL STILL GET HARD.. OLD FIBERGLASS TRICK..FOR FILLETS.. LETS THE FILLET AND GLASS SET UP AT THE SAME RATE.. NO SHRINKAGE..
My Feedback: (15)
CA
I picked up some Evercoat today which was darn near white ( a little more towards egg shell) and the hardener is pure white. I think this will work for what I'm doing.
Ian, white gel coated plane with seam lines. Finish color will still be white but I don't want to fill all the rivets and details in the skin. With this white filler, I should be able to go over it with a little coat of paint only, no primer to hide the filler.
It's all about preserving the sharp detail that came out of the mold.
Billy
Billy
My Feedback: (15)
CA
Joint down by my work called Ray's auto body, but there is a place closer to you over here on Sherman way called West Valley Auto color , they have it too.
I have some of the Splitsecond. worksgood seems a bit more yellowish though. But you're right, it is lighter. I won't be using much anyway.
Billy
Billy
