RE: dazzler arf
how was the parts that came with the plane?
the engine mount in the instructions is the metal clamp kind like mp pts mkII. the one on the plane is a plastic one that is a bit too narrow for the supertiger 45 i got. i think it will work out. but the instructions have the engine much closer to the firewall than possable with the plastic setup. i guess if it is heavy on the nose tail weight is not too bad.since it is far away from c.g.
the servo plate in the wing will not fit with the long square pieces it mounts on.had to trim it narrower. then had to widen the inside for the servoes to sit down. what a long pain in the A.
got distracted 9 1/2 weeks is on encore.
ok i may get it done tomorrow. i have no idea where i am putting the reciever as of yet. i got the 6200 with remote reciever.
