RE: dazzler arf
Red Rocket,
I am just finishing up my Dazzlar - what a piece of $%^&.
I hope it flies better than it builds.
I'm starting with my 40 LA and will put on the 46 FX when I get a chnce to break it in.
I will eventually do a piece on all of the build problems.
I had to add a weighted prop nut to balance, you may be OK there.
Receiver fitting is tight with standard 72 receiver - good luck on that one.
The wheel locks I got did not fit on the landing gear I got.
The motor mount hardware was metric not SAE as the instructions listed.
My buddy recommended throwing out their engine mount bolts - to soft.
Good Luck and report back on how it flies.
KW_Counter
