RE: Composite-ARF Integral, kinda build thread
What are the reasons why you would want to consider a pull-pull elevator system? Are you thinking that you could save some weight? Would you go with just a single servo instead of two mini servos? Which servo would you use, and would it be lighter than two mini servos? What about CG location? How would you prevent the plane from being nose heavy?
