RE: plane will not move
The motor probably started running backwards. Do you feel wind in FRONT of the plane? If this is so, stop and restart.
You can, sometimes, just jiggle the throttle stick and she will turn around and run the right way, without re-starting.
They often run backwards at first due to a flooded carb. regards, Rich
