RE: plane will not move
Definitely sounds like it might be running backward. A lot of times these engines come set very rich from the factory. Couple that with over priming the engine and it isn't hard to get one to cough when starting and spin the wrong way. You may also have the prop on backward; this could still provide a little thrust just not as much.
You may want to hook up with a club in your area and find someone there to help out too.
